Small hands are recommended when you install the two engine mount attchments SF234/323. Also, don't be surprise if you have to remove a couple of rivets from the side wall just to get enough space to stick your finger/washer/lock nut to the bolt. Not an easy task. Anyway, like most of the problems in this project they get solved, somehow, and after a couple of hours, a few sore knuckles and using an unusual version of the swedish language it's done!
