Keiths Web Site
Date:  2-25-2010
Number of Hours:  3.00
Brief Description:  Priming the undercarriage bits
Another painting session, while the snow fell outside. I am now virtually ready to install the gear legs but the logistics are getting complex. I need to do the following in this order:
1. Install the undercarriage and move the fuselage off the bench.
2. Trial fit the wings, and drill pilot holes for the flaperon linkages.
3. Remove the wings from the garage, so that I have space to start work on the canopy.
These all need to be done in one day, if Sandra's car is not to be left outside! It will also require additional labour, not to mention transport for moving the wings to Rupert's (son-in-law) garage. A dependency is a suitable Allen key, spanners, and grease, all of which are on order.
I also want to fill all of the rivet holes in the wings (cosmetic) before they are moved. Ideally, I should also replace two oversize bolts in the flaperons, again these are on order.
I had hoped to get all this done over the weekend, but snow and lack of tools is likely to result in delays.
