* Went shopping to puchase sundry bits and pieces * Add some placards * More (unsuccessful) investigation of trim speed. Did find out that putting a screwdriver in the pot with the master switch on causes a short that blows 2A fuses. Obtained more from my local garage. * Attempt to fill/bleed brakes from the top reservoir. Most people suggest forcing fluid up from the wheel nipples, Now I know why. But I did tackle a couple of leaks ;-) * Some prep work on a replacement flap mechanism. I was not happy that this was rubbing on the attachment bracket, again less than perfect workmanship.
