Brief Description: Attaching the Flap Handle Pushrod Assembly
Just one step and 4 bolts, but again this was a bit of a nightmare. I'm no mechanic! The assembly fits into two plastic Flap Handle Blocks which provdies a bit of resistance to moving the handle. It also provides resistance to getting the blocks into place. There's no easy way I could see to ensure the blocks are correctly aligned with the holes. So much pushing around with the blocks just hoping they would find a hole.
Picture 1 shows the blodks bolted in place.
Picture 2 shows the entire assembly. Some folk had found this assembly fouls the fuel line, but I had previously ensured that the fuel line was sitting flush on the floor so avoided the problem.
