Keiths Web Site
Date:  12-22-2009
Number of Hours:  1.00
Manual Reference:  P 31-03 Step 4
Brief Description:  Installing an Adel Clamp above the Fuel Flow Unit
The work for this step depends on which Fuel Flow Transducer is installed. Mine is a Flo-Scan.
This requires removal of one of the original bolts, and replacement with a longer one, with a spacer and another Adel Clamp on the top. I wish I had known not to tighten the bolt originally. It was easy to tighten at the time, but harder to undo with structure all around it.
Picture 1 shows the clamp in place. The wiring partially obscures the adel clamp and the longer bolt. The fuselage is still on its side.
Adel Clamp on FF Unit
