Keiths Web Site
Date:  7-23-2009
Manual Reference:  P 16-03 Steps 1-7
Brief Description:  Wiring the stall warner
Another first, crimping terminals onto bits of wire. Easy when you know how. But I didn't. Fortunately a bit of surfing found this article that explains what the inside of the terminals looks like.
http://www.aeroelectric.com/articles/terminal.pdf
I did have a ratchet crimper that makes double crimps, one on the bare wire and one on the insulation. I had half expected the crimp on the insulation to be less severe (given the larger diameter). It wasn't, so I don't know how secure the electrical connection is. Certainly the mechanical connection is sound. And a AVO meter confirmed that I was getting an electrical signal, so maybe I should stop worrying and press on.
Picture 1 shows my first attempts. These are earth straps.
Picture 2 shows the stall warner unit mounted on the required rib, which had previously been prepared with a couple of nutplates.
Pictuer 3 shows the unit wired up. The wiring goes through snap bushings in each rib to the wiring terminal on the rib root. I still have to attach this. I discovered I am missing a nut, so this will need to wait a while.
Earth straps
Earth straps
Mounted stall warner
Wired stall warner
Wired stall warner
