Secured the side wall wiring and replaced the side panel, just to check it out. Ran and secured both magneto wires along the side. Positioned all the copilot side wiring to the stick area. Positioned pretty much all the pilot side wires (there's a bunch more here), just have to run them through the wing spar still. Connected the ground wires. Connected the starter contactor, main contactor and the e-bus wires. Connected the main power line to the VP. Connected the 12v outlet to the batttery. I think I'm almost ready to fire up the panel. I still have to figure out the trim wires, and the ignition switch wiring. Again, I'm sure I'm forgetting something I did, but I just keep moving from one thing to the next. Getting close.
