Cut the sticks down to clear the slightly longer panel than my test panel. Then Drilled the holes for the set screws. The right stick was a little tall still, so used a file to file it down to size. Then I started in on the wiring. Ugh. So many wires it was hard getting started. But then I just started one at a time, routing them through the maze of wires, hoses and cables behind the panel, and then back where they belong. Drilled a few holes to provide easier routing. Basically got most of the wires that run to the very back or to the center console run. Now I can start hooking those bad boys up. Gonna be fun crawling to the back to install the strobe wire, and install the magnometer into the bracket I built. We'll see how that goes tomorrow.
