Greg's RV-9A Builder Site
Date: 11-21-2009
Number of Hours: 3.50
Brief Description: Wiring
Finished up the Autopilot pneumatic tubing, with some help from my friends at Lowes. Mounted the T's to the VP support braces. Then started sorting out the wiring. I first untangled the mess behind the panel, and got the VP plugs installed. Then one at a time, sorted out which wires go to what side of the airplane, or to the back. I seperated each wire and put it basically where it's going to go. Just a few questions as I have an ELT wire, not sure what that's for. I thought the ELT was battery powered only, but I'll have to check on that. Then theres a few position sensor wires that I have to figure out, and a mess of ground wires. I think I'll cut the sticks down next, and get that wiring done. Then figure out how to run wires to the back of the plane. Mount the magnometers, wire the strobes, and then I can close up the back end. Then I have to mount the black boxes behind the panel and finish up the wiring up there, then I can rivet on the top skin.
