Greg's RV-9A Builder Site
Date: 11-2-2009
Number of Hours: 2.50
Brief Description: Misc.
Finished installing the side panels, with the rivnuts. All went well, until the last one, which wasn't in straight when I pulled it, so it was a little loose, allowing the rivnut to turn when I would try to screw in the screw. So, I just superglued it to the support, stopping it from turning as I installed the screw. No big deal there. Then I installed the BNC connectors on the ELT antenna, both ends, and put the batteries in the ELT, and reset the internal switch, which had been tripped, apparently in shipping. Then I unrolled the gap seal for the wing and empenage roots, the rubber stuff, and straightened it out and held it straight with a weight, so it can work the kinks out in the next few weeks. I also tightened the firewall pass throughs for the control cables. I need my panel.... NOW!
