Greg's RV-9A Builder Site
Date: 10-29-2009
Number of Hours: 3.00
Brief Description: Interior, prop govenor
Started out by riveting the throttle, prop and mixture cable support bracket to the sub panel, and then attached the adel clamps with bolts. Then I worked on installing the interior panels, and got all the side panels pretty much installed, except for the arm rest panels, which will require a little drilling and screwing. Last, I double checked the full travel of the prop, mixture and throttle arm movements, and discovered the prop arm didn't have full forward travel, which is the most important direction. Without full travel, my prop won't develop full takeoff RPMs. So I adjusted that until I had full travel to each stop. I talked with Luke at Classic Aero and he gave me instructions to install the side panels, which I'll do tomorrow. I also sent Stein Air instructions to add my headset jacks to the panel, as my original location won't work because of the side panels. The good news about the side panels is that I'll be able to run a bunch of wiring behind them if i need to.
