Brief Description: Firewall Forward cleanup, gear leg fairings
Started out by fixing the things from my tech counselor visit yesterday. First, I replaced the alternator feed line. Then I moved some wires away from the engine mount, and put some protective sleeving where some fuel lines could rub against the mount. They all have firesleeve on them, so they probably wouldn't cause any problems, but what the heck? Then I removed the fuel purge line, and ordered a longer one from Bonaco. Then I worked on the main gear leg fairings. I got the hinges attached to both, and cut out the fingers to hold the fairing in place on the right one. I still need some hose clamps for the left one and the nose gear to complete those. Also, I will probably reinforce the "fingers" on the main fairings.
