Worked on the other wing tip, I get confused on which one I've done... anyway, drilled the ribs, and epoxied the inner rib in place, after marking position using the flashlight backlight method, and then marking for the holes. This one came out better than the first, of course, which is the norm for building this plane. While waiting for the rib to cure, I drilled and riveted on the platenuts on the nose of the cowl.
