Greg's RV-9A Builder Site
Date: 7-7-2009
Number of Hours: 1.25
Brief Description: More Wing Tips
Finalized the aileron alignment and tightened the jam nuts. Trimmed the left wing tip a little more, and fit it to the wing and drilled the initial holes. I was able to hold it in a better position than the left wing, and the initial fit to the aileron was better. Fit the edge rib, and marked the trailing edge. Removed the tip and drilled into the VOR antenna. Speaking of which, I had previously installed the VOR antenna in the wing tip, and had to butt the edge against the edge of the tip. Little did I know, the edge of the wing tip would have to be trimmed, about 1/16th of an inch to fit. So, the antenna had to get trimmed just a little too. Hopefully, that won't screw up my VOR/ILS reception. I don't think so, because this side gets "grounded" to the metal wing edge anyway, so I don't think it's crucial.
