Did a bunch of little things, like put the final screws into the tanks on the wings. Doing that, I discovered a rivet that I had drilled out a long time ago and never replaced. Easily accessed through the access hole, I can rivet it anytime I have some help. I also put in the nutplates around the access holes in the right wing, and used the tap to clean out the holes, and ease installation of the access doors later. I also attached the ground wire from the voltage regulator, and the fuel pump. I also permanantly attached the passenger stick, with a AN 3-13 bolt. That was pretty much it. My list is getting thin, and I'm needing that panel!
