Attached the pushrod to the center fuselage bellcrank, and then while I was back there, attached the shoulder harness cables to the longerons. That was fun. Then I attached some butt connectors, and then went back and fixed some that I screwed up. Then I removed some extra wiring from the sube install, that I figured I won't need. Basically, not a whole lot of progress....
