Trimmed the sides of the lower cowl. Lined up the hinges, with a slight aft rise in the hinge centerline as instructed and drilled the side hinges to the top cowl. Replaced bottom cowl, and marked drill locations to drill hinge into the bottom cowl. The sides came out real nice, but the aft edge, especially on the top cowl, will need some fill in work where I took off too much material. Gotta love fiberglass.
