Finished attaching the fuel pump and fuel filter brackets into the plane, then attached all the fuel lines to proper torque. Fabricated line from the pump to the bottom of the plane. In case of internal failure of the pump, the fuel will be dumped overboard, vs onto me, so that's a good thing. Then I put in the coax for both comm antennas, and crimped on the 90 degree connector I got from Stein. Figured out the connector needs to pretty much sit flush to the bottom of the antenna, so I had to make the hole bigger so that it could fully rotate on the pins and seat properly. Also figured out the screws for the bottom antenna are too short. I'll put my third order into spruce in two days later today. Had to crawl back into the tail of the plane which is always a really good time, trying to get my big butt back there without crushing anything. And then trying to get back out again. I picture myself getting stuck and having to call the FD or something.
