Greg's RV-9A Builder Site
Date: 12-29-2008
Number of Hours: 2.00
Brief Description: Top Antenna
Prepped the parts for the top antenna mount, dimpled and countersunk the holes for the platenuts, and installed the mount, with the help of my younger son, Max, who is 6. He was the only one small enough and tall enough to fit into the access hole in the tail, and then he was able to insert the nail pop rivet dimple die, so I could dimple the hole, and then he held the plate in position while I cleco'd it in. Then I pop riveted the plate to the stringers for stability. I ordered screws that were too long, so I have more coming from Spruce. Top antenna is on though, and I'll replace the screws when I get them.
Top antenna
pretty much centered
