Greg's RV-9A Builder Site
Date: 12-30-2008
Number of Hours: 4.75
Brief Description: Panel Platenuts
Prepped, primed, dimpled and countersunk the frame pieces for the panel, and riveted in the platenuts. Also riveted the platenuts for the panel supports that attach to the longerons. I also got Max (my 6 yo son) to climb up into the "hell hole" and get the zip ties started that hold the pitot line as it crosses over the bulkhead and arcs over to the other side. He couldn't tighten them, but I could reach them just barely enough to tighten them, but not to get them started. So, thanks again Max. Finally, later in the evening while the bowl game was on tv, I went back down and installed the control sticks. I cut the stick down so that with the stick grip on, the stick won't hit the panel. Then I drilled the hole for the retaining nut, and put the spacer in, and the nut on.
Control Sticks
