Greg's RV-9A Builder Site
Date: 12-28-2008
Number of Hours: 3.50
Brief Description: A/P push rod, Strobe Power, Top Antenna
Fabricated and installed the Autopilot pitch push rod, and attached to the bellcrank. At first, I was confused trying to get the full travel of the elevator bell crank and the servo, but then I figured out you only need full travel of the elevator, within the limits of the servo, so that the servo can't limit the elevator travel. Then I attached the strobe power pack on the bracket I had installed earlier, and looked at the attachment wiring a little. Finally, I started in on the top antenna, fabricating a doubler that will attach to the top stringers, for additional support. I also fabricated a spacer that the platenuts will attach to. My son, Max, can fit in the access hole for the old battery placement, and he will be a big help in dimpling and riveting in this doubler plate. I asked him to come help me and all I had him do was see if he could get his small body in the hole, and reach the top of the airplane where the antenna will go. Awesome.
Pitch servo, strobe power
Max's "hell hole"
