Greg's RV-9A Builder Site
Date: 12-27-2008
Number of Hours: 4.50
Brief Description: R. Tank Attach Bracket, vents, A/P servo
Finally able to work on the plane a bit after Christmas. Fabricated the right tank attach bracket, primed and attached the lower hole, waiting to match drill tank bracket before I drill the lower hole. Then I attached scat tube to the vents, and safety wired both ends on both sides. Finally, I mounted the pitch auto pilot servo, except for the push rod that works the bellcrank. I have to study about that some more before I do that. It was less than fun crawling back in the back of the plane, especially with the canopy in position. On the other hand, the canopy is getting smoother and smoother, and I'm real happy with how that turned out.
