Brief Description: Left Aileron and hinge brackets
Riveted entire left aileron. Had a slight hook from the last rivet, but I drilled it out and replaced and both ailerons are straight as arrows. I am real pleased on how they turned out. Drilled holes for the hinge brackets, reamed them to proper size, and then attached the hinge brackets and torqued them down. Had to modify the socket to fit inside the hinge bracket. Done with two ailerons.
