Started in on the flaps. Went to Home Depot Aircraft Supply and got a sheet of MDF that I can drill into. Then cleco'd the nose ribs/hinge brackets and hinge spacer assemblies together, match drilled them and then riveted them onto the spar and match drilled those. Fabricated the 906A angles, and the spacers. My spacers were made of .020 material and they required .025 so I am in the process of remaking them.
