Greg's RV-9A Builder Site
Date: 4-28-2009
Number of Hours: 3.50
Brief Description: Baffle, fuel overflow, mixture cable
I went out to Lowe's and bought some threaded rod, bent it to shape, and secured the outboard baffles on the bottom. Then, I fabricated and installed and safety wired the fuel pump overflow drain tube. Then, I drilled the hole for the mixture cable, and installed the pass through. Then I installed the prop cable, and loosely attached it to the prop govenor arm. Thats a tight turn it makes from the firwall to the bracket, but it seems to work just fine. I still have to tighten the jam nuts on both the bellcrank, and the bracket.
