Fabricated and attached one of the two flexible support brackets for the left muffler, waiting hardware from Larry Vetterman to finish that up. Then I started measuring and test fitting fuel lines and fittings that I'll need to get the fuel system finished up. Put a call into Bonaco for the fire sleeved hoses. Then I cleaned up in anticipation of my prop showing up, and low and behold, it did. I opened the box and it looks great. Prop bolts are a little tricky, but I'll figure it out. The yellow color of the nose cone is perfect and going to look great.
