Installd the ignition wire holes and installed the wires and installed the covers. Then I started on the fuel injection system, just able to get a few of the pieces figured out and fabricated for the fuel and mixture brackets. It took multiple attempts to install, remove, trim, reinstall. Then changed out the studs on the case for longer ones to attach the fuel meter.
