Greg's RV-9A Builder Site
Date:  3-9-2008
Brief Description:  Aileron Trim
Re-routed + battery cable slightly. I didn't like the way it was penetrating the main spar. It was bent so much to cause side loading on it, and I think, even with the snap bushing there, would eventually rub through. That's the ship's main power, and even though the engine would continue to run, nothing else would, so I moved it more in line with the ground cable. Then I started on the aileron trim, noting that I would have to take out some of the bolts and washers I put in on the control stick assembly. Bummer. I'm going to try to put a holding pin in while I take out the bolt from the other side, so hopefully, all the washers will stay in place, but we'll see tomorrow. Received a large order from Spruce, so now I can get all the electrical components installed soon and before too long, close up the back end.
