Greg's RV-9A Builder Site
Date:  12-12-2007
Brief Description:  Priming, deburring, etc.
Primed some parts, including the steps. Then I cleco'd in the steps, and bolted them in for good. Just need riveting. Then I put some foam balls that I cut slits in over the steps for shin protection. Thanks to Mike Schipper's site for that one. Then I primed some more parts, and painted the ELT door a bright yellow. Then I drilled a hole under the seat back bulkhead near the canopy rail for the pitot static tube that will go under there. Had to get a drill bit extension to get the hole put in there. Finally, I removed the top skin to deburr it. Got all the holes deburred on the forward section. Realized that I forgot to drill the longeron to bulkhead gussets on the forward gusset. I'll have to reinstall the top forward skin to drill those. I think I'll do it at the final assembly since no holes get coundersunk or dimpled. I'll just drill them and deburr them in place, then rivet them.
Foam Balls for Shin Protection!
