GOTTFRIED'S WEB SITE
Date:  12-24-2018
Number of Hours:  4.00
Brief Description:  Fitting the main transmission
Determined the shim thickness needed to have the rotorshaft come perfectly though the middle of the hole in the hood bracket. The right side frame support needed to be bent a bit to have the surface parallel to the transmission casting
needs to washers to aligh rotorshaft to hood bracket
Frame tap had to be bent. Shown before bending
transmission preliminary installment
