Brief Description: Installation of rotor shaft head bearing
After a a 3 year wait, my transmission for my Helicyle finally showed up and I test installed it into the frame checking or fit. I installed the transmission to the 2 frame brackets. One is already drilled, the other one will be drilled later after everything has been aligned perfectly. Next I intall the rotorshaft bearing into the head of the frame. Drilled the 4 holes as outlined in the video and shimmed the transmission to sit swuare and so it would not put any bending orce on the rotor shaft.
