GOTTFRIED'S WEB SITE
Date:  11-10-2018
Number of Hours:  6.00
Brief Description:  finishing rotor blade drag link brakets installati
The drag link bracket have the 3 bolts going through them at an angle. This means that the bolt head as well as the nut do not bottom out flat. I could have made a tapered washer, but decided in the end to use an end mill. I did not want to use an end mill whichwould create a sharp edge, so I bought an endmill with a nice radius to avoid any stress risers.
Milling the surface
Milling the surface
locating the existing hole
The finished drag link bracket
