Affter temporariily insalling the fuel filter, I had to put on the cabin halves to see if there is any interference. While putting on the cabin shells, I decided to finalize the bracket holding the front of the instrument pod in place. I centered the pod, drilled the 2 holes through the bracket into the pod; installed the 2 nut plates and installed the 2 crews.
cabin shells reinstalled to check fuel hose routing
