Brief Description: Fixing fuel leak on 2nd lower tank
Took level sensor out of lower left tank and made sure all gasoline and vapors were removed from tank and then proceeded to heat the insert in the way as described before. Again, this did the trick. and the bubble test with soapy water confirmed that the tank is now re-sealed. Prpceeded to reinstall the fuel level sending unit into the tank and did another leak test with gasoline and then installed all tanks in helicycle.
