Had ordered mor fuel fittings to give me some flexibility in fuel line routing. I usd some cheap vinyl 3/8"id hose to try different routing solution without cutting up the neoprene fuel hoses. I could not come up with a routing solution with the fuel filter in it's current location and the fiter mouning bracket will have to be modified. The fiter needs to move up by about an inch and a bit further to the rear to get some decent fuel line routing.Still not sure how to rot the fuel line from the aux. tank through the cabin shell. Always hesitant to cut holes without being sure it's the correct location.
