GOTTFRIED'S WEB SITE
Date:  11-23-2016
Brief Description:  Preparing fuel tanks for installation
Started working on getting the fuel tanks ready for installation.
Made some tapered mandrels and and superglued sandpaper onto themt to use them in a drill to get the different holes in the tanks to size and perfectly round. Started with the aux tank. Sanded the top of the filler neck to make it squarea nd then I proceeded to use my home made sanding mandrel to get the inside ID to fit the aluminum inset fitting. Next I sanded the holes for the outlet and the vent fitting. Woked all rather well!
sanded the holes to match fittings
Sanding filler neck to the right ID
