After watching BJ's video, I started working on the aux. fuel tank.First I needed to get the filler neck to the correct length and ID Found a tapered shaft and superglued 80 grid sandpaper onto it, put it into my drill and started to sand the hole diameter to make the aluminum insert fi. Process worked quite well and I have a tight fit with a nice surface finish for the O-ring to seal on.
