Finished the remaining push pull control tubes today. I still had to finish the tubes from the mixer to the swash plate and the smaller diameter rtube from the control stick to the mixer. Drilling the holes through the center of he tube was made easy when clamping the tube in the vice and then putting a round piece of stock of the same diameter into the drill chuck, aligning it with the vice jaws and then bolt down the vice.
