Shipped boost pump back to Airflow Specialties; they cleaned and bench-tested unit. Returned boost pump was reinstalled in fuselage; flow and tank capacity tests were performed with fuselage in level position. After testing, tail was lowered, fuel was poured from cans back into tanks and tanks topped off; total capacity 42 gallons. Naomi assisted with observations. Martin 3 hrs; Naomi 1 hr.
Flow test results: left tank fuel flow: 372 lbs/hr.; right tank fuel flow: 384 lbs/hr. Tank extraction test results, starting with 5 gallons per tank: Left tank pumped out 4.85 gals; 0.15 gals. unusable Right tank pumped out 4.93 gals; 0.07 gals. unusable
