Brief Description: Mount Horizontal Stabilizer pt. 2
Match-drilled #30 holes through stabilizer attach bars, rear spar and spar reinforcement bars; clecoed holes. Prepped and primed shim, stuck together with spacer and squeezed in vise to set. Measure to check that horizontal stabilizer was square with fuselage. Filed and deburred F-884 attach plate to fit between edges of front spar doublers.
