Brief Description: Rudder - 04 - Tip Rib & Counterbalance
- Riveted the right rudder stiffeners to the skin. - Straightened the tip rib (R-903) and counterbalance rib (R-912). - Clecoed the tip rib and counterbalance rib to the counterbalance skin and rudder spar (R-903, R-912, R-913 to R-902). - Drilled tip and counterbalance rib to spar. - Drilled counterbalance skin to ribs. - Clecoed the Right rudder skin to the rudder skeleton. - Temporarily put on trailing edge stiffener (R-916) for reinforcement.
Rudder tip rib and Counterbalance Assembly.
Riveted Right Rudder Stiffeners to skin.
Attached Right Rudder skin to understructure for final drilling.
