Brief Description: Spent time going over the wings
Today I got the wings set up in the shop. Than I spent the next couple of hours going over the build to the point it is now. I was looking for problems and areas that may need to be looked at closer. The only real problem I found was a couple of rivets that needed to be replaced and the Z brackets that hold the fuel tank on were drilled wrong, but the builder I purchased the wings from had disclosed that. Is it perfect, no but I have seen military aircraft in the past that looked a lot worse than this aircraft. So from this point on anything I post here will be stuff that I have made, drilled, riveted and bolted together....
