Did a rough positioning of wings to see how the fit and alignment might look. Snugged wing spars up to fuselage with 1/8" spacers. First pull from tail to wingtips was within 3/4". Tolerance is within 1". Added 1/16" spacer on rear spar, passenger side, Diagonals were 19'-6 1/8" vs 19'-6 1/4" Checked spar hole spacing. Front spar spacing = 44 1/2" Rear Spar Spacing = 44 1/2" Hole spacing should be 44 5/8" per plans.
