Back on plane, almost two months off doing other things.
RE-set and aligned right aileron and flap. Re-clamped inboard aileron hinge, was not straight. * Aileron leading edge shimmed up 1/8" (two popsicle sticks). Dirlled aileron hinge holes with long 3/16" bit. Then drilled & riveted platenuts. Installed aileron gussets. Installed right flap and aileron with rod end berings installed.
