Brief Description: Started right wing root skin and ribs
Started the initial fitting of the right wing flaps and ailerons. Installed #1 and #2 trailing edge root ribs. Installed root skin on ribs. Checked for 1/2" gaps between control surfaces and how straight trailing edge was. Removed flap and dirlled holes in root skin top side.
Initial fit up
Drilled holes top of root skin to #1 and #2 TE ribs
