Brief Description: New Extension tube for Dynon AOA pitot
Cut new 7/8" aluminum extension tube. This tube is 14" long. Slit forward end for hose clamp compression to secure it. Plan is to use hose clamp connnection as temporary fix until correct location of pitot is determined to ensure AOA function is working correctly. Not sure how far pitot must be ahead of leading edge to function correctly. May even be able to shorten it. Also cut side of tube for tubing connections.
