Brief Description: Initial fit and bend of Vans FAB
Starting fit of Van's FAB.
Installed angle filter retainers. Installed double washers between carb face and mount plate for engine sag, gaskets and control cable bracket. Stop drilled and put slit in aluminum top plate of FAB. Forward end of top plate needs to be bent down 1/2" for my installation. Installed airscoop and checked bend for vertical alignment.
