Brief Description: Start FAB carb heat and boo boo!
Started carb heat door fab.
Cut hole in aluminum top plate for door. Laid out extruded hinge that is supplied with FAB kit. Cut to 3" and drilled. Nooooooo! Hinge has to be reversed for fit and clearance. Read instructions stupid!!!
