Brief Description: Layout and mount of passenger door latches
Continued with layout and mounting of front passenger door catches and latch mechanism.
Spent a lot of time deciding best location of catches and pull line for cable run. Decided to give up on the snap bushings and go to 1/4" nylon tube for the tube penetrations due to the alignment issues.
Drilled 3/8" holes for catches. Drilled 1/4" holes for cable runs and catch holes in front and back formers.
