Brief Description: Tail access panel bottom of fuselage
NOTE: Following is OTR and not per plans.
Wanted to added an access panel at the bottom of the tail. Things end up there, dropped hardware, trash, varmits, etc. Also wanted easier inspection and maintenance of the tailwheel bolt.
Added .050 4130 angles for panel mounting and fabric termination. Drilled with holes for #6 nutplates and water drainage.
